Browse Forums Kitchen Corner Re: Brushed Stainless Steel Kickplate? 11Aug 30, 2007 1:10 pm I have reverted to username - mattwalker Carlisle Homes - Grande 43 My building experience is here: http://www.ourgrandeplan.blogspot.com Re: Brushed Stainless Steel Kickplate? 13Aug 30, 2007 1:31 pm I have reverted to username - mattwalker Carlisle Homes - Grande 43 My building experience is here: http://www.ourgrandeplan.blogspot.com Re: Brushed Stainless Steel Kickplate? 15Sep 07, 2007 11:54 am ![]() ![]() . CuttingEdge is that brushed aluminium laminate or actual aluminium? And whichever it is does anyone know where I can get it in Brisbane? I want to do this asap ![]() It is brushed aluminium laminate. Re: Brushed Stainless Steel Kickplate? 16Sep 07, 2007 12:01 pm great thanks just wanted to clarify that.
can anyone recommend a good place to get it around brisbane, is it just the laminex range and I can get it from their factory outlet at Murrarie? and how do you apply it? Is it just liquid nailed in place? sorry for the novice questions............ Re: Brushed Stainless Steel Kickplate? 17Sep 07, 2007 2:50 pm Yes the laminex range has a number of different types of metal laminates. They are more expensive than how I buy it. I purchase it from a supplier in a 150mm wide roll perfect for kickboards.
Liquid nails is without doubt the wrong way of fixing it. The laminate is only 0.7mm thick so if there is a lump of glue behind it shows up like Fred Nile at the mardi gras. You should use a contact adheasive that is applied to both surfaces allowed to almost dry and then placed together. Re: Brushed Stainless Steel Kickplate? 19Sep 13, 2007 10:59 am here is a link to a product similar to the roll described earlier
http://www.armstrongcabinets.com.au/sho ... 1975_2.htm I've purchase a length of this to trial before I buy a whole kitchens worth. I'll put up some pics when I receive it if anyone would like to see them. I'll need probably $150 worth to do my whole kitchen of 5.5m ![]() Re: Brushed Stainless Steel Kickplate? 20Jun 19, 2012 1:36 pm Can anyone advise where is the best place in Sydney to get brushed aluminium or stainless steel kick plates / boards at the moment for DIY? Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 7404 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 15460 ![]() if l cannot get a sandblaster would a sander with sandpaper be better then a wire brush 4 7987 |
