Browse Forums Kitchen Corner 1 Dec 19, 2008 3:08 pm hi all
just had my old 40mm thick laminex benchtop replaced with a 30mm Quartz one. Unfortunately there are still visible remnants of the black silicon beading on some side panels, from the old benchtop PLease tell me what I could use to remove that black silicon (which seems to be in the 'pores' of the laminex? Tried googling but no help. Have tried fine sandpaper but that did nothing... cheers Satz Re: how to remove black silicon from edge of laminex? 3Dec 19, 2008 4:53 pm satz Have tried fine sandpaper but that did nothing... Try some Metho. Please don’t use sharp objects on laminate, you could be very sorry……………… If all else fails, ring a kitchen company they will tell you what product to use. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: how to remove black silicon from edge of laminex? 4Dec 19, 2008 5:45 pm i used thinner to clean off silicon while it was still fairly wet. Not to sure how it works when it has been there a while.
Instead of having to buy thinner, try using nail polish remover it has the same chemical. How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6706 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12858 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7670 |
