Browse Forums Kitchen Corner 1 Jul 24, 2005 11:47 am We are building our own kitchen and are looking for some quality hinges and drawer runners. Does anyone know which brand/ type of hinges are the best quality and where we can locate them? (Preferably in NSW) We are looking for hinges that can handle heavy (steel) doors and runners that open and close smoothly and will remain horizontal even with heavy drawers.
Thanks, S&J Re: Hinges and runners 2Aug 27, 2005 9:27 pm I use BLUM drawers and hinges in my business. Blum TANDEMBOX drawers are rated at 30kg, 50 kg and 80kg. They also can be fitted with the BLUMOTION soft close system. They will stay straight!
If you are using steel doors I would need to know the weight and dimensions of each door before I could recommend a hinge system. Hope this helps. Yes, I had already tried searching those. In the end I am fabricating my own. 4 4766 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 11744 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 36546 |
