Browse Forums Finishing Touch 1 Jan 05, 2015 9:33 am Here's another thing I wasn't too sure of, painting the skirting boards. I've got the walls painted, but wasn't sure doing the skirting boards, in particular the masking of the wall to the skirting board. What is the better option to mask ? Masking tape run all the way around the top of the skirting board. A straight thin edge that you hold on the edge as you paint. I'm not worried about getting paint on the floor, as it will be carpeted/tiled afterwards, I just don't have a steady enough hand to attempt to do it without some sort of masking. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: How to paint skirting boards 2Jan 05, 2015 9:36 am If you're careful - you could cut it in - ie use a very good brush and take it along the edges. Not too much paint each time. Otherwise - tape is a good idea. A little prep is worth a lot of cleaning ... Re: How to paint skirting boards 3Jan 05, 2015 9:36 am If the floor doesn't matter you're half way home ... Re: How to paint skirting boards 5Jan 06, 2015 12:10 am I did the ceiling first, then the walls, now I'm down to the skirting boards. Found something that allowed me to do it without using masking tape, and seems to be rather quick... basically a straight edge that masks that section. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: How to paint skirting boards 6Jan 06, 2015 11:28 am bpratt I did the ceiling first, then the walls, now I'm down to the skirting boards. Found something that allowed me to do it without using masking tape, and seems to be rather quick... basically a straight edge that masks that section. Just be careful dragging it along - it can drag some paint with it ... Re: How to paint skirting boards 7Jan 06, 2015 4:05 pm Saint Mike Just be careful dragging it along - it can drag some paint with it ... Yeah, so I noticed ! At least being water based acrylic it can be wiped clean with a wet chux if done soon enough. Done the first coat last night, and most of the paint got only on the skirting boards/architraves. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . How to paint skirting boards 8Jan 06, 2015 4:16 pm If using an oil base, for others, I highly highly recommend adding a product called penetrol. Water base use Floetrol. It's the best product I've used that gives a really high gloss with no brush marks. Re: How to paint skirting boards 9Jan 06, 2015 4:35 pm Crazyk If using an oil base, for others, I highly highly recommend adding a product called penetrol. Water base use Floetrol. It's the best product I've used that gives a really high gloss with no brush marks. I'm using waterbased Dulux gloss paint, but haven't heard of this Floetrol or penetrol before. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Building Standards; Getting It Right! Is this acceptable in a new house build. Floors where installed by builder. Already chips in board and skirting is not flush 0 710 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 2617 |
