Browse Forums General Discussion Re: IS IT POSSIBLE TO GET A ROOF INSTALLED IN THE WINTER? 2Jun 13, 2019 8:38 pm Make sure you learn about roof structure , material quality,and speak to suppliers , all so when you get quotes that they pick up,you know a fair bit,much more likely to get a better job done properly if your not openly green.i would also ring suppliers to maybe find a few common high quality roofers, good luck. Re: IS IT POSSIBLE TO GET A ROOF INSTALLED IN THE WINTER? 3Jun 14, 2019 2:13 am BTW, check out metal tiles eg http://www.met-tile.com.au/, so much better looking than Colorbond. Depending on a roof size and complexity of the structure, will probably take a day or two to install metal tiles or metal sheets over existing roof frame. Re: IS IT POSSIBLE TO GET A ROOF INSTALLED IN THE WINTER? 4Jun 14, 2019 10:09 am It very much depends what type of roof cover you currently have and what you want to go to as well as the construction type of your house. If you currently have a tile roof and are going to go to metal sheeting then you need to change all the battens and valley boards. I'd also be adding anti-con. This take time. I'd also want to ensure the roof is tied down properly. Tiled roofs are heavy and vent through gaps under the tiles, tin roofs are light and tend to hold pressure more It's one of the reasons that metal roofs "blow off" more than tiled roofs. Make sure that all the roof is correctly tied down while the roof cover is off. They typically do sections at a time rather than just stripping the entire roof off and redoing. It takes longer but allows for any inclement weather. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4894 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 37115 0 12190 |
