Hi all, I made a 3 sided pallet shed. It is quite strong etc. except for the front, which wobbles slightly. I currently have a diagonal bracing piece of timber and while that is on, it is extremely solid, but when it's off, at it will need to be so the horses (who the shed is made for) can enter. Any ideas?
Wobbly 3 sided shed
I built it similar to this one, but without any pallets at the front. No cladding yet, but roof on.
http://www.goodshomedesign.com/diy-pallet-shed-project/2/
Once the cladding is fixed that will also help to stiffen up the structure.
Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and…
15/06/2023
2
Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some…
14/06/2023
Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as…
