Browse Forums General Discussion We're in the middle of reno'ing our laundry and the screed was sloped at roughly 1:100 to drain. This meant that across one of… 0 161476 Ground levels under the house should always be above levels outside to prevent water getting under the home, if not the your drainage should be designed to do so. 5 40774 I would be suggesting very subtly to your super "Is now the time you do the brick wash while the scaffold is up as I've heard the quicker you clean them the less the… 4 16145 |
