Browse Forums General Discussion 1 May 16, 2024 11:15 am Re: Please help me understand sewage plan 2May 17, 2024 6:33 am firsthome_2020 You need to locate those 2 manholes ( the black circles) and run a string line between them They may be covered in dirt or plants but do some hunting and you will eventually find them. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14785 Can you post your Architectural and Hydraulic plans so we can see how the system as a whole works? Without that no one will be able to give you any meaningful… 2 1000 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 14387 |
