Browse Forums General Discussion 1 Oct 16, 2023 10:17 pm Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design includes a corner balcony size 20m2 along primary road (setback 4.5m) and secondary road (setback 2.6m). It is more of a terrace and entirely sits above living rooms below. The Greenfield CDC clause 3C.14 (3) states that “The total floor area of all attached side or rear balconies, decks, patios, terraces…. within 6m from a side or rear boundary…must not be more than 12m2. We are thinking that since our balcony is front facing and not entirely falls under “attached side balconies” category, the above clause and 12m2 restriction may not be applicable to us. Can someone please help confirming this requirement? Our builder is not sure about this and says may be ok. We really want to confirm this before submitting to CDC. Any thoughts are appreciated. Many thanks. you need to make an application to your local council for this as they are the approval authority for driveways cheers Simeon 1 15265 Hi Minho I have heaps of experience in Ku-ring-gai with both DAs and CDC ( this is the main area we build in). DA's are taking 12-18months and CDC's we have been doing… 1 12874 It is so easy to do yourself. Even if you are not very handy. You literally only need a few basic things from bunnings. Honestly even with the most basic skills I know… 3 11960 |
