Browse Forums General Discussion Re: Floor plan help 21Sep 20, 2012 11:44 pm Just wondering if you have considered plans that put the kitchen wet areas close to the laundry? Bottom right corner? Always more cost effective to keep wet areas together. That said, I'd also seriously take into consideration where your hot water service is, and how far the pipes new to go to reach the kitchen. Minimize this. Waiting 10 minutes for hot water for dishes SUCKS Re: Floor plan help 22Sep 21, 2012 9:39 am thanks for your ideas! The plumbing shouldnt cost too much to change being on piers. Also, there is already hot/cold piping and sewer passing underneath the top right corner so we should be able to tap into that Our new bathroom is nearly 20m from the hot water service so we know all about waiting for hot water The new kitchen sink location wouldnt be any further away (maybe 1m if that) than the old kitchen sink location so hot water should be ok still tossing up about the pantry in the walk way or whether to recess it back into the study and lose precious room in there This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 14387 we need accurate dimensions as well as the number of bedrooms and bathrooms needed etc to make specific suggestions but, based on estimated rooms sizes, it could be… 1 1216 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 26239 |
