Browse Forums General Discussion 1 Mar 25, 2024 12:17 am Hey guys I'm thinking of installing a french drain, but my soil is clay. Water has been leaking into my room through a crack in the foundation slab after this heavy rain. I've been looking at waterproofing the foundation but I don't think I have the technical skill to pull it off. I feel I can change the pvc down spout/ elbow connection. But the side of the house is not properly draining the soil effectively. Maybe I should airate the soil or amend it. Make a french drain down the fence line. I'm not confident enough to dig around the foundation of the house, but water leaks into my rain after heavy rain, I had a huge puddle Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Drainage 2Mar 28, 2024 9:59 pm You can use a better version of a French drain called a cut off drain along your fence line and run a plastic membrane over the ground between the house and the drain pipe and will create good drainage. Re: Drainage 3Mar 29, 2024 7:42 am GroundZero "use a better version of a French drain called a cut off drain" That's the one, it's similar just dig the trench and the line the trench with some geotextile fabric and layer with some coarse aggregate. Place a perforated pipe on top of the aggregate. Fill up the trench with more aggregate and make sure it is compact (Careful not to crush the pipe!) HTH Regards -= Are you still using a notebook or spreadsheet to keep track of your customers and appointments? You need Simple Time Planner - Free Appointment Software =- 2 6386 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3448 13 7086 |
