Browse Forums General Discussion Re: Grouting Carport Post baseplates 2Mar 28, 2023 8:09 pm You would need longer then the specified anka bolts to allow for increase of the grout. You can mix the grout quite stiff and pack it like a mortar. I would probably use all thread chemset into the concrete with nuts in the underside of the post to raise and lower while still being fixed in place. Run them long to allow for the movement and then cut them off. I cut them +6mm or so past the nut and then fit dome nuts to cap, but whatever. Re: Grouting Carport Post baseplates 3Mar 28, 2023 8:17 pm thanks for the reply Ardo. have thought about using chemsets as you suggest, would be easier to plumb and would be securely fixed during construction. Re: Grouting Carport Post baseplates 5Mar 31, 2023 7:05 am Pulse Ardo is spot on, chemset and use washers and nuts above and below the plate. You can dry pack or mix the grout until flowable and box it up Yep, that's how I'll be doing it. Just ordered M10 Stainless all thread and Muti-se Vinylester (simliar to Ramset 801) from my favourite online supplier. If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4827 That just protects from further rust, l want first to apply a rust converter or rust killer to kill the rust thats there, whats the best one for galvanized steel 2 8168 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 26761 |
