Browse Forums General Discussion 1 Jul 21, 2019 7:32 pm Hi Building experts. I am wondering what I've done wrong to have the mortar in my steps match the house light grey I'm not sure what the mix they used in the wall was but I'm using the same sand and same brand concrete I mixed 1 part cement with 2 parts sand and it was very white, changed it to 1 part cement 3 parts sand and it was greyer but still too light Is there anything you could recommend? I tried to scrub new mortar mix in the gaps but think the mix is still too light I was thinking of sealing with a concrete sealer as when its wet it looks perfect Any ideas? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Mortar mix 3Jul 29, 2019 7:39 am How? I'm also wondering where the weep holes are on the house wall. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18541 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4749 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - Iām new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19552 |
