Leave the skirting off to lay floor coverings????
We are in the very early stages of a new build with Plantation Homes and are looking at our options for floor coverings.
We want Porcelain Tiles for lower level, Parador Laminate for common areas upstairs and a premium carpet for bedrooms.
Alternative (because I think carpet is a disgusting filth and dust trap lol) is to go with the Laminate right through the common area and bedrooms.
We have been told that we will need to get the builder to leave the skirting off so the Laminate can be laid to allow for expansion or we will need a ugly expansion joint against the skirt.
Does that mean the skirting over the Laminate will sit higher?
Do we just get the skirting left off the whole house so it can be set ate the right hight? or wont it be noticed?
Sounds like a lot of extra work to pay for after the builder has finished?
For example.. floor boards in common area with the skirting over the top, then walk into bedroom with carpet where the skirting was installed earlier. I assume there would be a slight change in heights that the skirt is installed. Is that something that will be noticeable?
So does that mean the skirts will be slightly higher in those areas?
They will be at a different height. Noticeable, I don't think so but the improved look of skirting over the laminate flooring will by far be a better look in my opinion.
Have worked out that if I do the "Common Area" upstairs with the laminate it will only be about 22 SQM of flooring. Bedrooms and lower floor will be Carpet / Tiles.
So I might see what it will cost from builder to supply and install laminate and I'll get the rest done
Only one option among many though lol
Have you got it sorted Roomeat?
Yeah I think so. Got prices to work with and select the best way that suits us
Apparently the skirting has been tacked on the bottom-most position which is great. means that we won't end up with a 'gap' between skirting and wall of unpainted wall when we come around to doing our floor.
8
12/03/2024
Hi there I'm looking for a independent company for a expert report on my blinds ,sheers & plantation shutters I'm in Melbourne
5/02/2024
5
Joe Apologies for the delay in getting back to you. If you haven't sorted this already you need to caulk this gap. Not sure where you are but if you are in Sydney I can…
