Benchtop over washing machine
I'm looking at renovating my laundry and it'll be the first time I've had a go at installing cabinets. My laundry is tiny, I have just over 1.5m to work with. My design is basically (left to right):
500mm width floor cabinet with sink/trough
640mm width space for underbench washing machine
space for end panel
290mm width broom cabinet
I will also have a wall cabinet against the broom cabinet.
What I'm not sure about is what else I may need for the benchtop to sit on. Currently, it will only have the one 500mm floor cabinet to sit on. After that, it is just empty space, so I am thinking I will need some sort of cabinet carcass for where my washing machine will go so that the benchtop will have something to sit on top of over that 640mm space. Or can I just hang some brackets off the broom cabinet and back wall for the benchtop?
I would love some advice on this.
Thanks.
That plus the cabinetry should support it - check with your cabinet maker.
Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the…
1/04/2024
2
Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them…
17/06/2023
Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m…
