Do I really need to cover my solar inverter?
Does anyone have any experience with this? Do I really need a cover or are they just trying to make an extra buck?
Did they look at the option of installing the inverter in the garage?
Does it need to be covered because it's got a LCD display or for some other reason?
If they're saying a cover is necessary are they "offering" to provide one or would they be willing for you to install one from Stratco/Bunnings etc that cost $100-$150 and that I've seen used for this purpose.
I'll make sure I have the choice, I have seen the bunnings ones which I could install myself otherwise they'll charge m $50 extra. I've come across these solar inverter covers which look nice too: https://sunnycovers.com.au/ but they cost a bit more.
Not possible to install in your garage?
I very much doubt that that is true.
Have you approached more than one supplier?
Should be getting at least 3 quotes and asking them questions like - Can you install my inverter in my garage?
I was looking into solar before the lockdown and almost went ahead with it. The solar company told me I'd need to get a cover since they could only install it on a wall that faces north meaning it would get full sun.
Almost all solar inverter manufacturers require your solar inverter to be away from direct sunlight.
Adding a solar inverter cover to your inverter protects your warranty.
otherwise, you can install it inside.
3
do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards
18/01/2024
2
Excellent, thanks for the tip ... not in Sydney, but I might give the Dy Mark a try, cheers
