I saw this house online and i really like the brick they used.
By any chance, would anyone know what brick was used, or something similar to it?
Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology.
Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window…
If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with…
