Brick Cleaning
7
No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my…
2/05/2024
3
Yep, efflorescence as mentioned above. You could look to clean it with a "acid" based cleaner and then seal with a penetrating sealer. This may not stop it entirely but…
14/06/2023
3
If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with…
