Building ForumBuilding Standards; Getting It Right!
4mm p/b wall cracks, replace or fill. Is there a standard?
Hi,
Am wondering if there is a set rule in regards to repairing plasterboard wall cracks. The cracks are in the vicinity of 4mm, caused by heaving, and originate from the corners of windows and door frames.
Obviously an obligatory patch job seems insufficient to us, wondering if there are any set rules or standards that dictate when the removal of a wall sheet is required.
I understand the need for stabilisaton of the slab prior to any repair work of course.
Thanks
Hi Velcro
Here's a list in order of sequence.
1. Locate and repair root cause of structural problem, eg, Settlement, vibration,expansion, stress failure, out of plane cracking...
2. Remove plaster board.
3. Repair or replace defective structural element/piece, corner window Frame/Wall may need stiffening, bracing, fixing.
4. There are codes for concrete repairs, for stud walls AFAIK NO
Thanks StructuralBIMGuy
Cracks Where a Wall Meets the Ceiling in garage
General Discussion
It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the…
18/01/2024
1
Brick wall small step cracks
General Discussion
Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions!
18/02/2024
1
Footing advice and core fill advice for 600mm retaining wall
Paving & Concreting
Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it…
