Advice needed - not quality plumbing work
Recently, we just found out the water has been leaking inside the wall so we cut out the internal wall and the water was leaking from the joint where the copper pipes & nuts were attached.
The plumber blamed that it was the manufacturer fault as the nut was cracked hence the leaking.
The damage has affected to gyprock wall, mdf skirting and also hardwood timber floor as I have not polished the floor yet.
Damage bill could go up to thousand of dollars & plumber has refused his responsibilities for poor workmanship.
Should i take this matter to Fair Trading or just bad luck on my part?
thanks for any advice
ttn
That should make him hop, skip and jump over your hurdles.
Nut is his problem, he supplied it. Fair Trading is the way to go.
Ed
will see how the timber floor people assess the damage first & then go from there
cheers
ttn
The nut you describe should not be behind the wall. Im guessing its a compression type nut known as a kinko nut. Its not supposed to be installed behind a wall.
The best advice you'd had is to allow your insurance company chase him up. Hes most likely not a licensed plumber and may not have insurance. Im a plumber and I have 10million dollars public liability insurance....he should too.
They charged our lines and there was a small leak, they blamed one of the other tradies for rupturing the main line in.
Another tradie saw water dripping down a cavity onto our slab and screamed at them THERE IS YOUR FUC&*ING LEAK.
What the plumber had done was screwed the shower rail into the tile then the wall, then it just (and only by 1mm) punctured the supply hose to the shower! If it had been 5mm over to any side it would have missed it.
So down came the tile, cut a hole in the wall, replaced the section of hose, re-patched the wall and re-tiled it.
YAY.... (insert sad face)
Plumbers are funny fellows some times.
Try marrying one
Pass...
Henley's plumbers were useles... Aaron is still re-doing most of our plumbing in the house...
cant agree more 5 years on and still having sewer issues the guy who did our house couldnt be trusted to fit a garden hose.
poor gradient if any,
rocks on top of pipes ( under slab)
dislodges connectors
pipes laid on top of rocks.
used chipboard with mortar mix on top for bath support.
What a moron and guess what im the one still paying for all the crap work 5 years later.
Now time for the plumbing commission and VCAT.
1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey…
12/11/2023
5
I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one…
2/05/2024
1
It's MGP 10 which means every length has been machine graded to it's specified engineered strength. It may not look pretty and if you where hand picking your timbers you…
