Brickwork standard
Page 2 of 2
The third photo looks exactly like our wardrobe. The mortar is very crumbly. I don't know why that's OK. We will be doing a lot of nailing for the shelves later on.
The brickwork on your last photo certainly won't pass the inspection. While i ain't expert, I have seen examples of inspection report. We will be hiring one just to put our mind at ease. We narrowed down to one company but too bad that they don't split brickwork/plate height and roof work. It looks like we have to go with a different company.
In regards to leaving perpends open I believe that in most instances as long as the joints do not exceed 12mm they may be open, although they have to be filled at intersections, corners, and top & bottom courses.
All joints above openings should be filled and extend 200mm either side of the opening, and the overall height of the internal wall should not exceed 2.4m. An engineer should be consulted in instances where wall heights exceed 2.4m or they are used in double storey construction.
This information is freely available via http://www.midlandbrick.com.au/brochure ... b311&scr=4.
I have contacted the other major brick distributors here in WA, although they have not committed to providing the same manufacturers recommendations.
Hope this helps
then there shouldn't be an issue with the perps not being butter up.
When the struts are fanning off the wall (out of plane) incorrectly then the wall is subjected to bending and cracking. So quite often it is a case of who takes responsibility for the cracking the brick layer or the carpenter? So how many brick manufacturers inspect roofs? ...I find most just pass the buck...so goodluck with that.
8
I am in the same situation, would you be able to give some insights in to this? I am in SA
30/10/2023
I wanted to get some thoughts on the quality of workmanship on the following brickwork? are there specific clauses in Australian Standards which relate…
