Concrete Path around house -expansion joints
My neighbour has done the same around his house and he has used his brick house and his brick retaining wall as formwork for his path without the black foam expansion thingies you commonly see down the side of his house or along the retaining wall (and to be honest I don't like the look of these things either).
Is this approach OK? Are there alternative expansion joint methods? I'm new at this and a bit confused. I want a job that is going to look good and also last without it cracking or potentially damaging the house (my house is Hebel and the material is softer than brick too).
Stewie
Once the concrete has been poured and cured the 10mm is removed and 'could' be replaced with a flexible jointing sealant like Sika flex in a colour closer to the concrete colour. This will help with aesthetics and prevent weeds or grass growing in the same 'control joint' space.
It also looks a lot neater.
So long as the path is below weep holes imoisture ingress will not be an issue.
Good to know, thanks onc_artisan
Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path…
5/12/2023
Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did…
20/09/2023
3
Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know.
