Hope someone can help me with this; as you can see in the pic, one of my door trim situated near my shower was starting to rot at the bottom
Removed the panel and now left with this...
Was thinking of redoing the silicone Inside the shower screen and putting some silcone between the tile and the wall. You can see the membrane under the tile, which stops at the trim.
You can see in above pic that the silcone is not done Under the shower frame...
Hopefully someone can advise the best way to fix without having to redo the tile and membrane.
Cheers
