Problems with shower niches??
has anyone else heard this? Should I take it out of my quote?
I heard the same thing that's why I didn't bother with them. Also, even though they are supposed to be slightly sloped they do apparently tend to gather grime in the corners.
Jo
It may depend on how good your builder/tiler is.
I initially had a feature tile in the niches, then decided that would be a nightmare to clean, so I changed to just having the plain tile that's in the shower in the niches as well, so I'm glad I at least did that!
I'll let you know if we ever have problems!!!
Quote:
A builder told me they dont reccomend these as they cause maintenence issues (ie they leak)
Out of the 3 builders we had dealt with, only one was against putting shower niches.
Same reason.
When I asked our builder, they said it depends on the tiler.
I still prefer niches than the shower cuddy... so we'll be having it in the ensuite.. but not in the other bathroom (wall could not accommodate a niche).
No problems , and yes it did have a slight angle in it. We will definately be having one in the next house but it will be bigger.. This time it will be 2mtrs long! ( the length of our shower)
No more build up than normal for grime etc and the water just runs out...
The whole inside around all the walls is coated in a fibreglass seal to stop any leaks etc
After browsing many display homes, we had decided on a shelf-type niche running along the length of our showers (similar to that in VJ's home).
Our builder however, informs us that the largest niche they can build is approx 45mm X 45mm!
I am so disappointed as this is not what we are wanting and I think that this small 'box' will look out of place in our large double shower in the ensuite
I just don't understand why we can't have what we want? Others have done it, why can't we?
This question is on the top of the agenda for our pre-site meeting with the builder at the end of the week!!!
I said I wanted to put them in our bathrooms, but wife said no. Said it was an unnesessary expense. I agree, it's not necessary, but it sure does make the shower look nicer.
Greg
I truly think it depends on the builder, and if he can be bothered forming them up and mucking around with them as to wether you get them or not.
I'll try and attach a diagram of how the waterproofing should be done - not sure how to do this.
2
I am not a brick expert, but rendering would be 1 option, it would be costly to do the entire house though....
24/02/2024
Hi all, has anyone been ask to do the weeds in their property while in the middle of build? We are under the impression that they are in control of the site while they…
16/04/2024
Have had a few issues with out recently done bathroom floor. Probably around 18 months old First there has been been a crack running through a grout line which I put…
