I recently had a shower screen replaced by insurance company under thier contracted trades person. After some time it is apparent that there is a leak issue from the wet room. We have had numerous trades people review the site, to find no apparent reason except for the three small leaks from the silicone seal around the shower screen. The shower screen sits directly onto the floor tiles. The screen was dislodged by my partner when he slipped in the shower. At the time of replacement, should the trades person have inspected the waterstop, water barrier prior to re installing a new shower screen. Would the trades person have picked up if further works were required, if the frame was not removed and only glass replaced. How do I detect a water barrier installed? How long should the waterstop and water barrier have or life span, and at what point is it due for replacement. How would or could a non trades person detect whether these need attending too. The shower was not leaking prior to the fall, but is know after the new screen has been installed. What experience have you had with these incidences, and have you been able to find other problem matic areas affecting the containment of water in instances of falls withing wet areas.
If you can provide some guidance or ways to check the waterstop or water barrier that would be great.
Thanks team
