Reece (Mizu) push plug - any leak?
Has anyone heard of leakage problem with the Mizu plug?
http://www.reece.com.au/bathrooms/produ ... -push-plug
Fitzy
But buying the rubber seal for the pop-up cover part is impossible.
After 5 years the seals hardened and started cracking.
You can buy a new cover complete with the seal at Reese for $17.50 but they carry only female covers.
We have male (under cover fitting).
Tried to buy a set of 4 PROFORMA seals from Reese but they don't fit and black ones are poorly made.
May need to replace the covers and pistons for about $20 a basin.
Anyone have seen the seals that work for the Mizu 32mm pop-up?
2
If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while.
8/10/2023
Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while…
9/01/2024
3
Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit.
