Hi,
I know most would say to rip up bathroom terrazzo and replace with tiles - but has anyone seen pics of a glossy paint or great stain treatment to make a brown terrazzo bathroom floor (including shower area) look hot?
Thanks from a nearly-first-home-buyer trying to figure out reno workloads
Painting or Staining Terrazzo Bathroom Floor
If you are talking about a terrazzo floor that is the true 1930+ polished/coloured and aggregate terrazzo, then it is actually only about 13mm thick and is integral with the rest of the next 80-90mm of concrete floor, taking it up will involve taking up all the concrete and going down BELOW the floor to the substrate (soil) if it is concrete slab on ground, or to some some form of suspended timber/fibro subfloor that the concrete ( about 100mm of it) has been laid on top of. Then you will have to waterproof it again to modern standards.
It is fine to tile over existing terrazzo, but that may well give you clearance problems as that will/may raise the floor by the thickness of the tile and adhesive that you use. A good tile adhesive and tile will last another 30 years - at least my parents floor did.
hope this helps
hope this helps
7
I’m definitely no pro, but from my own DIY attempts it’s something painters can do, it just tends to cost more because it’s fiddly and time consuming compared to…
19/11/2025
5
Totally doable as a DIY, just be ready for a lot of prep , cleaning, sanding and a good primer are the main things. Once that’s right, the top coats are pretty easy,…
18/09/2025
3
Covers or awnings can definitely help with rain splash, but if it’s proper rising damp then it usually needs more than just a surface fix. The moisture will just keep…
