exhaust fan options for flat roof
Has anyone come across this issue before and found a suitable exhaust fan? I don't want to have an in wall exhaust but that might be the only option.
Do you have exposed beams? I hope so because I may have a solution...
A builder suggested creating a ceiling cavity by putting in a ceiling below our exposed beams. That way we can install a decent ceiling fan/heater/light. Otherwise we're stuck with another cheap looking plastic white fan in the wall. (Apparently exposed beams give you higher than normal ceilings so bringing the ceiling down below them only brings it to normal height...)
Are you heading for that solution?
I'd be interested to know what you do and how it goes. My reno work is still a few months off (alas) but I'll let you know what happens.
We actually have got rid of the beams and replaced the entire roof in the living area which we have extended but we are still left with beams in the rest of the house. We originally had the wood boards as well on the ceiling but step one in the re vamp of the house was painting these white but I was too scared to do the beams at the same time in case i hated it. However I will be painting the remaining beams white after we have finished.
My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is…
25/02/2024
There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually…
12/04/2024
Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about…
