bathroom spas? .. anyone got em/prices?
we're at build stage and were thinking to go for it if its within our budget .. but rite now i dont even know what budget to set! ..
any experience sharing would be great! thanks!
We are getting a spa bath for our home....ours will be the Jamaica 1790mm. Heres a link which shows all the models in Raymor's Carribean range and with prices too
http://www.tradelink.com.au/resources/a ... Raymor.pdf
Hope it helps
Similar pricing for rectangle spas, shop around, Tradelink, Reece, Swan, Builders Renovators Warehouse.. they all have specials here and there - my advice is just never pay what is on their tags - they have a fair bit of room to move in my experience.
When it comes to installation, I'm sorry I can't help, our builder is installing ours for free - our job was just to get it!
well i guess i need to rely on my builder to tell me if we can supply our own and they'd install it at a cost or if we've to go to their select shop which could mean a lot more $$$ .. i'll watch this thread a bit more ..
Remember you need access to the pump for maintenance and repairs.
Being one who sells spas, yes they generally start just under the $1000 mark for a standard version (or less if on sale). My recommendation, get one with the extra small jets in the lumber area and for your feet, to get the massage feature of a spa rather than just bubbly water. Hot pumps aren't always an extra expense worth paying. I think its Decina that uses the normal heat generated by the pump to help keep the water at a constant temp, and if you're in warmer climates its just not necessary to worry about at all.
When i got mine they had a touch pad option or the standard button, i went with the standard button but it means my heating element comes on all the time with the pump, if i had paid extra for the touch pad could i have controlled these separately? I used my spa (for maybe the 5 time in over a year
PS i highly recommend getting a TV in the bathroom ...
Even though this includes plumbing, heat pump and some minor tiling for the step, the price does seem a little outrageous. Assume the price of the Angelique 1300 with Pump at $1000, this leave ~$2000 for the rest.
Problem is, I am not sure how to deal with it. The builder won't let us buy our own and they install, even if they did, the install price would be $2k or more.
The other option is for them to put in the plumbing and just tile it up. Then we source and install the spa bath afterbuild. The builder will insist all the tiling is done to seal the wet area and provide the warranty. So essentially we waste money on the tiling and then removing it later for the spa bath.
In addition the Angelique 1300 is the baby model, we would much prefer the 1500. So at a minimum, we go back and ask for this upgrade, they will probably hit us up for more cash on top of an already outrageous price.
Particularly frustrating because we had the bathroom resized to allow the corner spa and double shower put in.
This is a real pain, I would very much appreciate any ideas that folks have on dealing with this. Seems like a catch 22 to me.
http://www.burdens.com.au/categories.ht ... ubcatid=15
We are paying $2065 to upgrade to our spa (RRP is $2200), that includes taking off the credit for the standard bath, our builder having to amend the bath hob, and installation of course.
If l were you, l'd print off examples of prices for the Angelique (like above) and show them to your builder and get them to justify exactly what their $2995 figure comprises of!
They should quickly back down and reduce your quote to a more reasonable figure. If they do, have your upgraded model prices at hand and tell them that this is what you now want.
Good luck and keep us posted.
If so what were the "special circumstances" under which it was granted? "Note: If the development consent is for 'dual occupancy' an owner-builder permit can only be…
15/02/2024
6
Tradie may sit at home but will need to get house plastered as well or will you sit it out?
