My toilet worked fine until a couple of days ago, when the cistern failed to fill up after flushing.
I removed all the connections and the inlet valve (it is a standard
Fluidmaster 400UK Bottom Entry Toilet Inlet Valve) to check for possible errors. The water pressure if fine, the connection hose is not blocked but not a single drop of water makes it to the cisternBefore I remove more parts or call a plumber, can someone perhaps shed some light what the problem could be? I assumed there is a straight through connection from the water supply to the cistern and the sudden failure does not make sense to me.
Clearly it appears there is a bit more to it, appreciate any help to resolve this.
Thanks and regards
Chris
try turning off the stop valve
unscrew the fill hose from the cistern
aim hose into a bucket and then open stop valve
just to confirm you do have water flow
I already tested the fill hose and made sure it works ok - there is no blockage. The problem is somewhere between the two endpoints shown in my photograph on the left and right.
Did you check the seal under the float?
No I did not, I removed the float so it can not be the problem.
The float activates the seal bit if you have lifted the top cap off, then you have also lifted the seal.
The only thing left is the plastic pig's tail in the shaft.
You were right the problem was that 'pig's tail' thing in the shaft deteriorated over time and blocked the water supply.
The first plumber I called, looked at it for 2 minutes then said I need a completely new toilet costing $2'100. The second one not only identified the problem properly but fixed it in a couple of hours for a fraction of the price.
Thanks for your help.
