We wanted to have the bathroom floor same height as the bedroom, all rooms are on one same level of concrete floor now. My question is if I can use power tools to remove 40mm of the current concrete floor so when tiles plus adhesive put down they will meet my timber floor level in the bedroom? Is it safe to do so in terms of the structural of the slab? This is on our first floor, suspended concrete floor is 220mm thick.
Thanks heaps!
Bathroom floor level
Thanks heaps!
Suspended slabs are engineered to have a certain depth and cover on reinforcement.
If you just take to the slab and grind or cut out a recess you may cause an issue.
You would need to speak with an engineer and also check with whoever inspected your reinforcing steel to make sure all the proper cover was installed to see if it is doable.
It is something that should always be checked on plans prior to construction.
Also, you can also consider laying out waterproof laminate instead of tiles (e.g. Aqua-Step).
1
isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest…
2/08/2023
4
they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo…
17/09/2023
13
interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing…
