I am looking for suggestions on relocating the outdoor AC compressor unit. Is that a straightforward task ( for a licensed AC installer) or something of a “bad luck, cant do it without breaking the wall “??
Pic as attached
you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case…
I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I…
Just bought a new 80 sq m apartment under construction in Perth. There is not a lot of space for things (and I'm a collector), but there is a long wall in the living…
