Insulation Requirement .. R ? & Sarking ?
Btw, we're in Sydney North-West .. where the temperatures are 2-3 degrees higher or lower depending on the season ..
In the sub-tropics it can reduce air con energy consumption up to 20%.
It costs 3-5m2 and it is the most cost effective material to help improve summer cooling. Consider also using it on sun exposed walls e.g. west/east wall.
It's usefullness in keeping the house warm in winter is much more limited as most heat loss is not from radiation but by conduction. Foil easily conducts heat outward. That is why you also need batts which slows this form of heat transfer.
Chris
Does make any sense to use Air-Cell Glareshield or Insulbreak instead ??
Chris
Chris
Composite materials like Air cell and Etherm have some bulk insulation effects but no where as much as batts or cellulose.
Whilst radiation protection is purely based on the surface composition of the material, bulk insulation effectiveness is dependent on the thickness (or more correctly on the number of air spaces that are isolated from one another).
Air cell is relatively thin compared to an R 3.5 batt. The probably are about R 1.0 equivalent (which is inadequate for most climates)
I'm considering using Air-Cell instead of sarking AND the bulk insulation (R2.5 batts) in my stud walls. I've asked around if Air-Cell makes any sense but haven't got a definite reply.
Chris
Would you? Or wouldn't you?
dynomite is right, you will get a big benefit from the relective properties of sarking, and anticon or air-cell provide bulk insulation benefits as well. If you have a flat roof I think sarking is required by building code, but steeply picthed metal you don't have to (but you should!). The pay back in reduced heating costs will be very short.
There is lots of options, but what sort of roof do you have (metal / tile / other) - is it pitched or flat or skillion?
Sorry to hijack the thread
We'll have a tile roof (25 degree pitch). What would you recommend?
www.bradfordinsulation.com.au, www.air-cell.com.au) under the tiles, ensuring its 'sags' ie has an airspace between it and the tiles and then use well installed (no gaps) bulk insulation (batts) directly on the ceiling between the joists. This should give you the right balance. Sarking improtant under metal roofs for condensation less so under tiles, but essential because of its reflective properties - ie keeping out summer heat.
I am assuming it is a new house and you are located in adelaide ... it is pretty easy, I would just use any reflective foil sarking (Related
3/04/2024
3
Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a…
27/03/2024
Hi all I’m in VIC and had some storm damage in my garage a month ago. Gutter found not fit for purpose. Insurance company saying the guttering and flashing to be fixed…
6/07/2023
2
1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it
