What is normal humidity in sub floor
Initially, the humidity level was very high at around 85% and after putting the fans in, the smell has improved, but the humidity levels will not go below 76%.
For those who have a sub floor, what is considered to be normal levels of humidity here? I'm located in Sydney.
neosdad i suggest ongoing over 60% Humidity is a problem. If the forced ventillation is not effective you may need to consider additional moisture mitigation measures such as drainage works and membranes. Keep an eye out for mould growth in wardrobes., furniture and clothing etc. Its very common in Sydney.
With that's said, I'm unsure if the weather forecast (or my humidity sensor) is stating absolute or relative humidity readings
1
1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it…
26/07/2023
5
Yes, get a builder, make sure he is experienced and a registered building practitioner
