hi everyone
with the warmer temps winter grass has just shot up all over the place on my front lawn.. reading around on google it has suggested that May is the time to use chemicals to kill these and during warmer months the weed is too strong and will out grow any chemicals sprayed..
is this true? if so, should i simply wait until May before covering the front lawn with this stuff? (Wintergrass killer)
THanks.
too late with wintergrass?
5
No I don't believe it is too steep. We are doing one with similar fall to yours in Lindfield ( see attached plans) It will need to be split level and you will need to…
23/11/2025
3
what is the tile thickness or weight per m2? what stud spacing? 6mm on 450mm stud spacing is good for 40kg/m2
