LED 12V Garden Lights flashing
4x 1.8m led strips under benches (4.5watts each)
8x 5w spotlights
the led driver i am using is a ROBUS 100w driver.
Issue i am having is that when all lights are connected they flash... when i remove the last 4 spot lights the rest of the lights work fine? Total run from power to last light is roughly 24m.
Any ideas on what could be the cause? Perhaps its the driver?
What strip lights, what spot lights, which Robus 100w driver?? All these lights are in series?
2
I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf
4/10/2023
2
AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre…
31/01/2024
1
There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have…
