Thanks in advance for your responses.
Leaky tap
The o ring keeps it watertight.
I'd take off the mixer and see how tight or loose it is. Don't over tighten it.
It could be a number of things.
How old and what brand is it?
Meanwhile I have put a bowl underneath to catch the leak.
Not sure about the brand, some no name cheapy, it's not even that old. Will take a closer look on Saturday, may be time to upgrade to something better.
You can get a quality kitchen mixer from $100.
It can be done from within the cupboard by undoing the lower end, and tightening the top connection. If it still leaks the inner O ring needs replacing
Not to hard, really. Undo the mixer, lift it up and check the connections. When checked replace. Worst case is it still has a slight leak in which case get new "o" and fit them. No need to hit panic stations just yet.
^^^ X2 !
worst case scenario me thinks to change the braided hoses.
Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead…
18/01/2024
Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers.
