Decking and Pergola Permit.....who did or didnt?
I for 1 do not know of many diy'ers that do in most cases. Myself included. I have never had a problem selling a property with a deck or pergola without a permit.
I think the problem also relates in the huge costs in obtaining these permits. $800 odd dollars for a permit to build a 3 x 4mt deck in our council.
No wonder so many people do not obtain one and just go ahead anyway.
Many people I have spoken to in our estate have not bothered to get one, many due to the cost and lengthy associated hassles.
Our council doesnt require a permit for a deck or a small built Pergola.
really? I thought if the deck is over 10m2 a permit generally is required.
My council is no permit if under 500mm from ground height.
I refuse to pay 1600.00 odd dollars for a low level detached deck. what a money grab.
I wouldn't be so sure! We are also with whittlesea council and they have been cracking down on illegal decks & retaining walls. A person around the corner copped a $4000 fine and a criminal conviction for a retaining wall without a permit. We are building a deck out the back of our place and checked with council and if you build on ANY footings then you need a permit and the amount of cr@p involved is a joke. As the deck we are building is large 30m2 we have decided to put a slab down as you don't need a permit if it's on a slab regardless of size. I think it will end up cheaper and alot less bullsh1t to go through doing it this way.
Check your states building regs as they over rule any council guidelines.
Good luck.
There's a lot of huffing and puffing by the bureaucrats about the ills that will happen if you don't have permits (and keep them in a job). What happens in real life? How much active enforcement of the rules do councils do? and if they ever did stumble upon a properly built deck where the owner didn't bother to have permit, what did they actually do about it? All I hear of is 'may's but haven't seem much evidence of anyone actually getting caught or having to rebuild. Most bureaucracies operate on fear, uncertainty and doubt.
We didnt get a permit for it as at that time, if it cost under $5000 no permit was needed.
We have now sold it and built our new home. We are now under construction of a 8 x 7mtr verander which is up against a fence line on a slab and also a carport. We got the drawings done thru a draftsman which cost $1000.
Plus council permits cost $650.
A big pain in the @ss is that the council is strict and over compensating.
Eg. is we had to dig out a 8mtr long x 1.5mtr deep x .4mtr wide footing along the fenceline that was filled with $400 of rio and then filled with 4mtrs of concrete @$650. Thats because it had to support a fire rated brick wall. So so far it has cost us a small fortune for really nothing to show.
BUT
our mates thought theyd get away with building a deck with spa etc in their backyard with out a permit. They had a dissagreement with their old nosy neighbours and the council got involved. Well $6000 later after correcting the construction and penaltys, they said it would of been cheaper to get a permit.
These days in our area, you can only really not have to get a permit if its an pergola (uncovered) less than 10mts sq (tiny)
Is it really worth the chance not to get one? depends on the size of your project, and how well you get along with the neighbours. But dont forget that the council often gets on nearmaps and looks at new construction going up around our area and sees if it has a permit. Even a house down the road had to move a cubbyhouse off the fenceline cause they were dobbed in being visable front the front of their home.
Really up to the owner I suppose. For me, Id rather be safe than sorry. Plus I suppose it is nice to know that if a earthquack did happen, our house might fall down but at least our 1hr firerated wall will still be standing.lol
Also, going through the motions of a permit for newbie (like me) was beneficial with all the additional things you learn through the process.
Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks
5/06/2023
Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find…
12/06/2023
1
You wont need a permit to put in non loading partition but you will need a licensed plumber and a licensed electrician
