Bad stone bench top
are you able to post a photo? What brand is the stone? And what is the stone mason who installed the stone saying? Sounds like he needs to return and finish the job off properly.
Some stone companies do have slab seconds which can save the stone masons money, and these may contain imperfections.
I would get the installer back to take a look.
Hope this helps.
Thanks for the tips. This one is called Smart Stone. I can't post a pic because the glare from the kitchen light means the photo doesn't show anything useful and that is when it looks it's worst
Smartstone is a good quality product.
I would be getting your stone mason back as its his responsibility!
I don't understand then, if it's good quality stone why it looks so bad. How can it go wrong?
There are many of reasons it can go wrong!!!!
The stone comes polished from the manufacturer but if not treated well in the factory or onsite during installation can be damaged. I have seen finger prints left on stone from silicone and the glue they use. I have also seen the surface damaged by dust from plasterers.
First port of call is the stone mason, have you been in touch with him?? Its his responsibility!!!
I just saw him today. But I'm sure he thinks I'm exaggerating since you can only see how truely bad it is at night. He is going to contact the stone company. I guess I just have to wait and see what happens next. I was so excited about getting stone. I hope they come through for me.
What brand of stone is it??
If you don't have any luck with the stone mason then get into direct contact with the supplier. They will be able to send someone out to write a report on it.
Still having problems with my Smart Stone bench top. The supplier has been to look and claims the stone is fine and the lighter parts that appear to me to look like stains in the stone are just from light reflecting off the Quartz. I want to know if this is normal and I have to live with it and accept that's just what Gris Roca looks like or if they may have given me a slab from a bad batch. I don't know enough about this topic. Give up or keep complaining?
Call Smartstone directly and ask the questions. If you don't like the answers ask for a SmartStone rep to inspect your stone.
He says it's the light shining off the Quartz
You really need to go directly to Smartstone and cut the supplier out at this stage. If SmartStone says there is a problem with the stone then the supplier doesn't have a leg to stand on.
Seems like dark coloured manufactured stone is supposed to look a bit crappy. That's what everyone is telling me anyway. My only other avenue is qbcc
That's not right at all!!!!!!!!!!!
I fit dark coloured stone tops all the time without any issues??
You say you only other options is qbcc(not sure what that is) but I will ask again, have you called Smartstone directly and asked them to come out and do a report on it???
12
These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is…
14/09/2023
4
Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges.
15/08/2023
1
You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not…
