how to remove black silicon from edge of laminex?
just had my old 40mm thick laminex benchtop replaced with a 30mm Quartz one.
Unfortunately there are still visible remnants of the black silicon beading on some side panels, from the old benchtop
PLease tell me what I could use to remove that black silicon (which seems to be in the 'pores' of the laminex?
Tried googling but no help.
Have tried fine sandpaper but that did nothing...
cheers
Satz
Could try shelley's silicon remover.
Try some Metho.
Please don’t use sharp objects on laminate, you could be very sorry………………
If all else fails, ring a kitchen company they will tell you what product to use.
Instead of having to buy thinner, try using nail polish remover it has the same chemical.
tried some nail polish remover (my wife's, not mine!)
and that got rid of most of the black silicon remnants
Might get hold of some thinners and try that for the really stubborn bits...
cheers
Satz
How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity?
26/08/2023
the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath…
4/11/2023
1
You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of…
