Knock down or renovate
We want to add a second story and pretty much redesign the first floor. Only the 4 outside walls would potentially stay. 5 bedroom house about 330sq mtrs if we do everything which includes 7x8 garage.
I’m getting conflicting price points and wanted to see whether to renovate or simply knock down and start over.
We are looking at medium finish and the volume builders for total rebuild are about $1350-1500/ sq mtr and custom builders to Renovate are $2100-2300/ sq mtr.
We are on a flat block. But the price difference is massive.
Are we better off just doing a demo and starting from scratch with a volume builder whose plan we like?
Am I missing something here? I know volume builders take 5-6 months longer, but it’s a difference of potential $150,000 to renovate vs start over.
Are there substantially more costs associated with a new build?
Thanks everyone!
Thanks everyone!
That's a big House and great size garage.. .. I would have built a larger garage
It's hard to tell without photos and further information
Points to consider
1. Is your current house worth renovating Vs the new house build?
2. Ideally you would need to Design/Model both options, view Pros and Cons, extract data, costs and compare
and most people don't
3.They go the easy option... new house get 3 quotes and compare the market
4.Rule of thumb, Renos cost 30-50% more than a new build,
As there's more work involved in repairs, compliance, and Overheads,etc,etc
There can be
1.if you don't compare & check costs
2.If you dont have the soil report eg Geotech
3.Engineering costs are firmed up after you have committed, by that time you are locked in
4.Work out the surprises before hand, own copyright of the plans and Data, get 3 quotes, Pick your preferred builder and negotiate a fair price
Well I guess that’s not comparing apples to apples. Custom builders cost similar whether it’s to renovate or total rebuild, and the quote you got seems about right. You’ll get a better quality build and one designed specifically for your site, your lifestyle and needs.
Volume builders don’t renovate of course, and are cheaper due to economies of scale. On the flip side, options are limited and site supervisors can be spread rather thinly over multiple builds, so quality can be affected.
Also, the Bim data and information also comes in handy during the build, when checking. hth
2
I'm on that journey. I had to demolish a single story brick veneer on concrete raft slab about 220 sq meters for about $19k. They took forever to get a permit and I…
26/08/2023
the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath…
10/01/2024
1
if the original house is in good condition most of what you listed could be added in stages without the need for KDR and costs and disruption of having to live elsewhere…
