What discount do the trades usually get on supplies
What discounts do trades generally get on supplies compared to say, hardware store retail prices. I realise there is a range, and it depends on the volume of purchase.
I’m just trying to get an idea of whether it’s worth sourcing these products myself, or just getting the trades to source it.
Timber Frames and Trusses= x%(I realise there is a range)
Concrete(bulk for slabs)=
Steel reo for slab=
Gyprock=
Electrical Supplies=
Plumbing Supplies=
Bricks=
Insulation=
General Timber Moulding Doors Skirts etc=
Colourond roofing gutter etc=
Anyone in the know on this? Do you know if the volume builders generally get much more than the trades?
Thanks.
Concrete(bulk for slabs)= Concreter usually gets this much cheaper than any one else because they buy heaps. However the issues is they have been known to put a large markup on the stuff when you go into extra concrete.
Steel reo for slab= Sometimes you can get it cheaper depends where the guy buys it from but it wouldnt be for than a few dollars less per sheet.
Gyprock= This stuff is only aroudn 3.50 per square meter. How much cheaper can you really get it.
Electrical Supplies= Yeah if you look hard enough. Electrictions only go to one shop. It may not be the cheapest.
Plumbing Supplies= Actual pipes etc leave it to the plumber. However fitting wise if you savey and no what to look for you can get some good quality imports.
Bricks= Builder organise this. In fact the bricklayer usually just turns up. You need to make sure he has everything.
Insulation= Depends on what you want.
General Timber Moulding Doors Skirts etc= again carpenters dont buy this stuff.
Colourond roofing gutter etc= Not sure. Usually just best to leave it up to the installer just in case you run short.
I guess it leads me to my next question. How much cheaper do the builders generally source things like bricks, frames trusses, mouldings etc
This has always puzzled me why the average Joe who walks through the door with cash in his hand gets slugged top dollar, when the builder who admittedly deals in much greater quantities and puts things 'on the slate,' gets discount.
Then when things get tight and the retailer has to chase the builder for late payment or misses out if he goes bust, the little bloke still fronts up with his cash, to get slugged again.
If you are an owner builder you may get a slight discount, but you will be competing with the big boys.
Volume always seems to win... unfortunately for the OB. However in this day and age, with online sales, I can't see why you should pay much more than builder prices for any product, particularly if it is a simple transaction with the OB doing all the hard yards in terms of providing the specs they need for the product. profit is profit regardless of the source...I know i'll be bargaining hard when I OB.....
i guess you can call me an OB, however i have appointed a builder to oversee, co-ordinate and procure as well.
Invariably I have been able to get a lot of things much cheaper than him using contacts that I have.
- Volume (as somebody mentioned above) and
- customer-come-back.
An Owner Builder's purchase is "one off". If a seller gives a discount to the builder, the builder is more likely to "go back" to that seller.
That's exactly my point though. In this day and age, you can find out roughly what the builder pays for a product. So even with a builder price, you know that the supplier is profiting. Use that as your baseline. So assuming there is competition in the industry, I can't see why the supplier won't offer an OB or one off purchaser a builder price, if
a) it still brings in a profit
b)they know that the OB is savvy enough to push the issue, (or will source it somewhere else if the right price is not met).
but you will never find out what the "kick back" aka rebate is which is a way of protecting the real identity of a "builders"price
fair call..
However, the point of my original post was to break this down. There must be a few in the know without a vested interest in the status quo
fair call..
when I was going through interior design phase, the designer said she can get quotes "cheaper" than anyone else so she proceeded to get quotes for doors, flooring, tiles, and a few other bits and pieces. All the while she knew I was an owner builder. Before she released the quotes to me she wanted me to sign a document to say something along the lines that should I decide to return any of the items mentioned that she would be entitled to keep a 15% builders margin. I was quite furious and refused as she knew I was going to do my own procurement and I thus crossed out that clause and signed the document and then she released the quotes. The prices she had were outrageously expensive. I was able to source the same spec of each item at up to half the price she quoted me through other suppliers. What i found interesting was that the suppliers she used refused to requote or change the prices for an OB - they justification was that i was a "one off" client whereas she gives them a lot of business and they were not willing to jeapordize that relationship. Well, I have done several developments over the years so I am hardly "one-off" and lucky I have enough contacts to get around such issues.
Moral of the story: the industry generally looks after the industry
The mark up they put on is also to order, carry the cost on account, pick up, deliver etc., which is not as minor as it sounds.
OB' can always find cheaper prices if they are prepared to do the legwork and shop around for bargains. Builders won't 'shop around', they will go to a standard supplier, hence wholesalers wanting to keep them. I have sourced heaps of bargains by going to Fwles auctions, getting display stock etc but there have been times that picking it up (ie. paks of 5mtr timber) have been a trial
My OH is a tradie but I have still sourced most things, and cheaper than he would have. He does get a better price on things like cabinetry, slate etc. A
Auctions are GREAT for good deals
People seem to forget that as an owner builder you are still buying things in bulk. Whether its floor tiles or timber. You will be buying a lot. People seem to forgot this.
5
Always get multiple quotes, no matter how reasonable/cheap you think it is. I remember getting a few quotes for a pool fence, roughly around the same price, thinking the…
22/01/2024
36
"Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets
3/11/2023
1
Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single…
