Browse Forums Safer Living Re: Security System, CCTV and Intercom 6Jun 20, 2012 11:50 pm Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: Security System, CCTV and Intercom 8Jun 22, 2012 8:30 am AubinGroveFan CCTV pre-wire: It says that it includes the run of stranded Cat5 data cable and 4c power cable. If an analog camera is to be used, a pair of passive baluns (data to coax adapter) will be required. Not sure what sort of wiring that is... Cat5 cable is the same cable used in computer networks. It's saying, if you want to use an analog camera, it will use the same Cat 5 cable but you will need adapters at both ends. Re: Security System, CCTV and Intercom 9Jul 17, 2012 2:19 pm Finalising our smart wiring plan. We chose to prewire 3 CCTV cameras, however not sure if we'll need more cameras??? How hard is to wire CCTV cameras after the house been built? We'll probably go with wireless intercom as well instead of paying another $400 to prewire it (hope it's right decision)... Re: Security System, CCTV and Intercom 10Nov 08, 2012 9:38 pm Can anyone recommend me Home Monitoring and Larm Combo. Essentially I am looking for system with around 4 motion activated cameras, which is connected to DVR and also streams on the ineternet. The system has capability to send me an email when motion is detected so I can veiw the live streaming on any mobile device. Moreover the motion should also trigger alarm which can be disabled remotely. I would also like a GPRS/GSM backup for the system just in case the the culprit were to cut the wire, so that i could still veiw the primary camera via mobile device, by ringing the GPRS GSM number. ashrey|^| Re: Security System, CCTV and Intercom 11Dec 02, 2012 6:30 pm You're going to get sick of me posting this...but if your a little computer savvy you can do a full IP camera system no issue, I went through a few before settling on xprotect does the streaming to a phone thing, does the alerts thing (will SMS you an alert with attached screen shots etc...) Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Security System, CCTV and Intercom 12Nov 27, 2014 3:58 pm This could help you decide for your system http://articles.chicagotribune.com/2012 ... ide-alarms Re: Security System, CCTV and Intercom 13Jan 05, 2015 10:26 pm It's best to pre-cable every provision possible that you may require in the future - ease of running cables is only 30% of the Reason why, lots of people end up having lots of dramas with certain cabling post build which is only realized at the end. It's too hard to say whether it will be cheaper doing it afterwards this can only be answered by looking at the property. There is no need to waste money running 4 core cable alongside CAT5/CAT6 purely for the provision of Analog Cameras via use of Balun, any proper smart wiring company who does CCTV pre-wiring will know this. Having intercom separate to the CCTV can be more convenient, if you dont intend to have live 24 hour display of your CCTV in a common room, having an intercom as-well as a better choice and will probably save more power. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 21245 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 10568 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 7161 |
