Browse Forums Kitchen Corner Re: 300mm kitchen bench overhang with 20mm thinck stone 2Jan 24, 2012 8:07 am Our Homebuilding Thread 17th Nov - 1st meeting with PJB architect 27th Feb - Signed contract 23rd Mar - Plans approved 3rd Apr - Slab laid 18th Apr - Roof On 10th May - Lock-up 26th June - Handover Re: 300mm kitchen bench overhang with 20mm thinck stone 3Jan 24, 2012 10:06 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: 300mm kitchen bench overhang with 20mm stone 13Jan 27, 2012 1:01 am CC101, No, there is still enough gap between the stools and the bench that you don't bump your knees. Chatz Re: 300mm kitchen bench overhang with 20mm stone 14Jan 27, 2012 6:17 am Does it make a difference if you have waterfall edge as you then have support for the 300mm overhang on each edge?? Re: 300mm kitchen bench overhang with 20mm stone 15Jan 27, 2012 9:23 pm thanks chatz. kdgirl - waterfall edge will have support only at the end. stone's manual says that any overhang more than 200mm should have some supports underneath at some regular distances. Re: 300mm kitchen bench overhang with 20mm stone 19Apr 28, 2012 6:32 pm deb17 We have 200mm overhang on ours. I have seen Henley Homes with ones that hang over much more than ours. I would say 400mm. does that henley homes with 400 overhang has 20mm stone? Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 4081 In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 8034 This is the best I have, as it is plastered internally now. I should add there is a steel post in the corner of the room between the window and the glass sliding door,… 3 856 |
