Browse Forums Building A New House Re: How long should a slab cure before framing? 2Feb 07, 2011 4:18 pm Where you are coming from is where you are going to... Re: How long should a slab cure before framing? 4Feb 07, 2011 5:00 pm Where you are coming from is where you are going to... Re: How long should a slab cure before framing? 5Feb 07, 2011 5:08 pm guys here is a link to a guide to AS 2870 - 1996 "Residential slabs and footing contructions: http://www.concrete.net.au/publications ... ityWEB.pdf Refer to point 6.4. 3 "Curing" "Curing is the process that controls the loss of moisture from concrete after it has been placed in position (or during the manufacture of concrete products), thereby providing time for complete hydration of the cement to occur. Since the hydration of cement takes time – days, and even weeks rather than hours – curing must be undertaken for a reasonable period of time if the concrete is to achieve its potential strength and durability. Curing may also encompass the control of temperature since this affects the rate at which cement hydrates". Recommended curing periods are: n Slab Surface I nterior 3 days Exterior 7 days n Slab Edge Non-aggressive or saline 7 days Is your builder following the standards? Re: How long should a slab cure before framing? 6Feb 07, 2011 5:13 pm http://www.saiglobal.com/PDFTemp/Previe ... 0/2870.pdf Australian Standard™AS 2870 - 1996 Residential slabs and footings— Construction Re: How long should a slab cure before framing? 7Feb 07, 2011 7:36 pm Here's some more info - http://www.concrete.net.au/publications/pdf/Curing06.pdf Next time I'd put it into contract that the slab is to be left alone for 3 full weeks minimum - no load and definitely no driving over it with bobcat to install stormwater pipes Foot traffic only, no tools of any kind. My signature is distracting people from my wise posts ... Re: How long should a slab cure before framing? 8Feb 07, 2011 9:04 pm Lex good work.... It’s recommended to achieve the max slab strength that its covered and cured for up to 28 days. This process achieved 95% strength.... I've noticed that’s all major builder air dry the slab for 3 days and then start building the frame... this process only achieves 40% strength.... If you are wondering why your walls have cracks in them maybe it’s due to your builder not curing the slab... Re: How long should a slab cure before framing? 9Feb 07, 2011 9:40 pm That is 28 days at 20c and average humidity. a 5 deg increase in average temp would reduce cure time by 25% ... an average summer day will be 28+ reducing the cure time. Winter is a different story. Where you are coming from is where you are going to... Re: How long should a slab cure before framing? 10Feb 07, 2011 9:46 pm Don't confuse curing time (7 days is good) with design strength (after 28 days). If putting up a timber frame, 3 days is OK. If loading with brickwork best to wait 1 week for on-grade slabs and 28 days for suspended slabs (with all props removed before loading with brick walls). Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: How long should a slab cure before framing? 11Feb 07, 2011 9:49 pm Where you are coming from is where you are going to... Re: How long should a slab cure before framing? 12Feb 08, 2011 6:58 am I had my slab laid on a Monday, frame was started on the Wednesday... I really don't think that was enough time, they told me a week... Re: How long should a slab cure before framing? 13Feb 08, 2011 7:14 am Victoria_g06 I had my slab laid on a Monday, frame was started on the Wednesday... I really don't think that was enough time, they told me a week... Hey Victoria_g06, Builder make most of their money with the first 3 stages of the build. They just rush the job so they get paid... its all about cash flow these days, they have a business to run and bills to pay. Re: How long should a slab cure before framing? 14Feb 08, 2011 8:28 am Hi Guys, My slab was poured last Tuesday in 38C heat. On Wednesday (22 hours later) the frame was put up, again in 35C+ conditions. This was followed on Friday by 189mm of rain. I am concerned that these extremes will have impacted on the integrity of the slab, which sits on piers at one end. Do we have any recourse with the builder if the house develops cracks over time? Despite these conditions the slab has not a single hairline crack or crumbling edge - could the weather have created a super slab capable of withstanding the crazy weather in melbourne?!? First Home Builders Clarendon Roeberry 29 Arena @ Officer Colours Selected 12/08/10 Tender Signed 26/08/10 Contract Signed 12/10/10 Building Permit Issued 22/12/10 Site Start Due 14/01/11 (fingers crossed!) Re: How long should a slab cure before framing? 15Feb 08, 2011 8:40 am The rain would have helped a bit. Give it another 2 weeks and see what you have. Where you are coming from is where you are going to... Re: How long should a slab cure before framing? 16Feb 08, 2011 8:41 am Arena537 Hi Guys, My slab was poured last Tuesday in 38C heat. On Wednesday (22 hours later) the frame was put up, again in 35C+ conditions. This was followed on Friday by 189mm of rain. I am concerned that these extremes will have impacted on the integrity of the slab, which sits on piers at one end. Do we have any recourse with the builder if the house develops cracks over time? Despite these conditions the slab has not a single hairline crack or crumbling edge - could the weather have created a super slab capable of withstanding the crazy weather in melbourne?!? The only recourse is your statutory warranty of 7 years for any structural defects. I think its poor workmanship that the builder has erected the frame after only 22 hours of laying the slab. For a slab to cure it must be kept moist and allowed to dry slowly. I think your luck here as your slab required a pier which adds to the structural integrity of your foundation. Most people freak out when they get the site cost estimate from the builder but what they don’t realise is that the foundation is the most important part of the house. Most people would rather spend the site cost money on in house upgrades rather house than on a strong super reinforced slab. Re: How long should a slab cure before framing? 17Feb 08, 2011 9:27 am Thanks tstr1a We will definitely keep an eye out for any damage resulting from our speedy start and get onto the builders straight away! First Home Builders Clarendon Roeberry 29 Arena @ Officer Colours Selected 12/08/10 Tender Signed 26/08/10 Contract Signed 12/10/10 Building Permit Issued 22/12/10 Site Start Due 14/01/11 (fingers crossed!) Re: How long should a slab cure before framing? 19Feb 08, 2011 11:56 am Arena537 Thanks tstr1a We will definitely keep an eye out for any damage resulting from our speedy start and get onto the builders straight away! cracks start to appear after 2 weeks or so - keep an eye Re: How long should a slab cure before framing? 20Feb 08, 2011 2:17 pm I was told by the concreter they will allow my slab to cure for 5 days,on the 5th day the frame was stood. The frame is relatively light and the weight of it on a slab would be negligble. The weight comes with the bricks and roof tiles sitting on the frame and by the time thats completed your slab would have had plenty of time to cure. STEFF62 Framing should be fine, but he will only be able to nail the baseplates in, I wouldnt think you can dynabolt them after 24 hours. My question is, how is he… 1 6028 8 10242 Houses have been framed on floor joists since settlement, chipboard flooring is only around for 50 years or so, so why would it not be satisfactory? However exercise skill… 3 17759 |
