Browse Forums General Discussion Re: Are pavers good for driveways? 2Mar 13, 2024 2:55 pm Hi, I have had them in the past and the pros are:
Cons, can be more expensive than straight concrete and also take longer to install Regards -= Are you still using a notebook or spreadsheet to keep track of your customers and appointments? You need Simple Time Planner - Free Appointment Software =- Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 19960 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 14518 9 26039 |
