Browse Forums General Discussion Re: Flush Internal Doors 6Feb 03, 2024 2:58 pm Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments from others here and the opinion of some house designers. I've repaired doors where the skins are peeling off and it is not a complicated job so keep that in mind for the future. Yes, I know one should not have to repair a product that should be constructed properly in the first place but that's "modern" society for you. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16268 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 2960 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5869 |
