Browse Forums General Discussion Re: Facade Render cracks 10Jan 18, 2024 10:02 am alexp79 This is most probably the reason After further questioning the builder, I was told that there is an EPS foam on top of the board and he told me the render has a mesh. I am not satisfied with his answear and the cracks are getting wider. Re: Facade Render cracks 11Jan 18, 2024 10:24 am The mesh is often stuck on wall first then rendered over, which means it does nothing Not to specifications Get a scope of works in writing before start, needs to be opened up How will attach JH sheet to foam, getting you on merry go round Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 7307 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17884 |
