Browse Forums General Discussion 1 Nov 13, 2023 8:21 pm We have an apparent "dead-end" water main running straight through our front yard and up to an old easement on the street behind us approx. 3m above our ground level. We've had some heavy flooding coming from within the retaining wall, Council believes it has nothing to do with the water main and must be a neighbours leak (Neighbours have seen no issues with water, and I've personally been there checking their water meter). Plumbers, builders, and a surveyor all believe it's the council water main problem. Council have said "there seems to be some sort of step-up elbow bend in the water main here". Any ideas? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Water Main Flooding? 2Nov 14, 2023 7:33 am not sure what your ehoping to get from the forum. the source needs to be found to determine the remedy and the liability. At themoment all there is from all parties is speculation. Gonna have to do some digging Re: Water Main Flooding? 3Nov 16, 2023 7:15 am Until you find the cause of the flooding you need to take action to mitigate potential damage to your home. Get automatic float pump and dig a pit then connect to power and outlet hose to your stormwater drain Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog The bottom of the downpipe has been taped (see the black tape) to seal the necessary gap between the downpipe and the adaptor that would normally prevent the downpipe… 3 10002 Hi all I'm currently building a duplex in Sydney and we need to do a new water connection to the second unit. The water main is on the other side of the road so we need… 0 4468 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 19111 |
