Browse Forums Building A New House Re: Prewiring a House for Data, CCTV, and Future-Proofing 17Jul 11, 2023 4:58 pm kvazer 2. Data points for CCTVs. There is absolutely no need to keep them on Wi-Fi if you can have them running via Ethernet. Plus they are powered via PoE. except that wiring up such a system can easily add a grand to a wireless set up (if you're expecting your builder to do it). Its not like the wireless cameras are eating up bandwidth or batteries anyway. They activate on motion and barely use either resource enough to worry about it. The only conversation that remains is that of cost and how much of a headache one is over the other. Another point for wireless is that you also have the benefit of testing the positioning before you comit to the installation position. Wireless is winning teh race on most things. just embrace it. Re: Prewiring a House for Data, CCTV, and Future-Proofing 18Jul 11, 2023 5:11 pm ponzutwo kvazer 2. Data points for CCTVs. There is absolutely no need to keep them on Wi-Fi if you can have them running via Ethernet. Plus they are powered via PoE. Its not like the wireless cameras are eating up bandwidth or batteries anyway. It depends on the use case. If you hook up your cameras to NVR, then yes, they will always consume bandwidth. I am not sure if you even can do that with wireless cameras to be honest. I would not go that far and say that wireless is winning. It depends on a person and their tolerance to potential issues. Ethernet is definitely better but if it is worth the cost depends on personal preferences. Re: Prewiring a House for Data, CCTV, and Future-Proofing 19Jul 11, 2023 6:45 pm alexp79 I would say even more, with Wi-Fi 6 you get speeds up to 9.6 Gbits/s, it is almost 10 times faster than the best LAN (which gets you 1 Gbit at best, while most of the home networking devices still work over 100 times! slower 100 Mbit LAN). In this context, your main bottleneck will be always your NBN connection. PS. And Wi-Fi 7 with speeds up to 40 Gbit/s is already on its way. that's not true. NBN may not even be in play when you transfer large volumes of data between a PC and a NAS for example. or have multiple people trying to stream different things from NAS. modern PCs/routers come with 2.5Gb LAN ports nowadays. i think it's only TVs that are lagging behind on 100Mbit, but until you get into 8k streaming you're probably ok with 100. also those WiFi speeds of 9.6Gbit/s number you're quoting would be total combined bandwidth across all channels. which is shared by all devices. also in ideal conditions at a particular distance from the router. totally different ball game when you're at the other end of the house from the router. of course one could get into mesh networks to fix those problems, but mesh repeaters would also benefit from a fixed cable connection if you don't want to have lots of them. Re: Prewiring a House for Data, CCTV, and Future-Proofing 20Jul 11, 2023 7:39 pm Well, if TV just needs 100 Mbit, then 9.5 Gbit/s can easily handle a dozen of TVs simultaneously. How many do you need for your NAS? Netflix streams 4K/UltraHD at only 15 Mbps, by the way. And yes, mesh network is an absolute must for big house. It worked for me in getting all non notified rain days removed from the builders claim, although the LDs was only $50/day 7 6604 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 17440 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 8229 |
